Best guess on a replacement prop?
Mousejockey
1983 Beachcraft, 16 1/2' OMC 3.0L
There are no markings on the current prop which is badly chipped on the edges, 3 blade aluminum.
When I had the drive rebuilt (water pump shaft failed) the guy said the prop "looked abit small for the boat"
I tried with no luck to see if there was a 'factory' prop and have no clue on what to get, the prop charts are all greek to me =/
Re: Best guess on a replacement prop?
Ayuh,... Welcome Aboard,.... drag yer old 1 off to a Prop Shop,...
They can measure it, or rebuild it, or sell ya another 1 like it, usually with pretty good advice...
Bein' an ole Stringer drive, may, or maybe be an issue findin' a prop...
They had some funky, unusual mountin's...
