Best product to reattach trim to tilt cylinder?
mojokim
I need to reattach the Cobra trim to the sides of my tilt cylinders. Any advice on what would be the best product for this? Epoxy? Doug Russell sells new ones, I wonder if they come with some sort of adhesive. Any thoughts are appreciated.
CCrew
Re: Best product to reattach trim to tilt cylinder?
New ones come with adhesive. They're basically a fancy sticker. <br /><br />You can use 3M trim adhesive, it's available at Wal-Mart, that works.
mojokim
Thanks. I think I may even have some in the garage somewhere. I have to order one new one but I want to reuse the one I have.
crazy charlie
Use auto molding adhesive or if you have bellows adhesive.apply it to both surfaces and let it dry.then spread a thin layer on the cylinder and press it on ,it will be permenent.Charlie
mojokim
Thanks for the advice. I appreciate it.
