Best way to clean a gear lube monitor
summerwind1991
Got some green 'gunk' at the bottom of mercruiser bravo 2 Gear Lube monitor, what's the best way to clean this crap out
tashasdaddy
Re: Best way to clean a gear lube monitor
post in the i/o forum, for better results.
Summerwind, Remove the rmonitor container and use some solvent (acetone, paint thinner, gasoline) to loosen and remove the gunk. Make sure it is dry and then reinstall.
