Bilge pump confusion
ibew1933
My Johnson auto bilge is staying on.I am going to replace it and have been online for hours and still not sure what brand is best and should I go to a manual pump with a seperate float switch?
Re: Bilge pump confusion
Ayuh,..... Rule is 'bout as good as they get, 'n Yes, I prefer a separate switch...
Take it out, make sure there is no debris stuck inside the float mechanism and then try it. A simple leaf or a stem from a leaf can jam the switch into a constant on position.
Solittle
Rig it so that you have a float activated swithch AND a seperate manual switch.
