bimini top support poles
Exotic4x4
Just bought a taylormade bimini top for my Larson from Iboats.com looks great not installed yet because I've been debating on getting the bimini rear support poles and eliminating the rear hold down straps. are these poles just as ridged? Will they break kink bend or twist off? I think they look cool u can cruise with your top at an angled position without laying the top flat down on the sun deck. Need someone's .002$
Re: bimini top support poles
my searay had rear support poles. I liked them.
Fireman431
They are called struts. Well worth the money.
MH Hawker
They work very well, their not for looks their for use.. I even added 2 extra ones to mine.
But I have a bit more room to do so.
26aftcab454
only 2 bolts extra to remove when time to takeoff bimini.
belleview3
Well worth the money. Get metal hardware instead of nylon, gives better support. Most biminis tend to flex (wiggle) laterally, especially with nylon hardware. I replaced mine with stainless and virtually eliminated the movement.
Fireman431
I really love mine. Only 2 bolts extra to remove when time to takeoff bimini.
Don't use bolts on the struts where they attach to the gunwale. Go with the quick release clips. Very easy if you decide to lay the top completely down and no tools required.
