Platypus E65
- Joined
- Mar 30, 2010
- Messages
- 58
I've got an 18' SSV Lund that leaks pretty good and I want to replace some rivets now and later on, seal it with some Gluvit, something I haven't done before. I was planning on ordering 1/4" blind rivets but, I don't know which length I should order. Which size would work better on a Lund aluminum hull?
I also noticed that there is an option to order steel or aluminum mandrels. which one would be better for an aluminum boat to be used on the sea?
As for Gluvit, how much would I need to seal the hull and do I need to apply a second coating? Would sealing just the bottom of the hull be good enough or do I need to seal both sides?
Thanks.
Thanks.
