block replacement 4.3 88 mariah
is there a web site that will cover the rebuilding / specifications and such. just ripping engine down now....dying for boating weather.. thanks for any help..
Re: block replacement 4.3 88 mariah
Ayuh,........... You're Here....... What do you need to Know,..??..??.....
We don't particularly Care about What Boat it's In,......
Just tell us Everything about the Engine,+ Drive you've got,.... Why it's Broke,+ How you're Fixing it.......
We'll do what we can from There............
I just replaced the outdrive and bellows last year put it in last spring found the block had a canyon ij ust got the replacement block and need the torque for everything crank and up i thought the might be a link to mercs manua
And not all of them are the correct one for you. Matter of fact, the one you need #7 is not online at all.
thanks for info where is #7 book? Thh motor came out of 88 pichup bad oil usage the boat is just like new everything i want to transfer the boat 4.3 into new block recomendations?
i'm thinking putting crank and all in replacement block have some auto experience this is how you learn should i install video cam ha
#18 will Work for what you're wanting to do,.........
You've got Alot of Measuring,+ Mic-ing to see if your donor Block is In Spec for the Internals of the Boat motor.......
My Guess is the Pickup motor Bores are going to be Out of Round,+ Need Machining Anyways......
You might want to bring Both of them to a Machine Shop,+ Ask them to build 1 motor out of Both........
i have help flying in from calgary in a week or two i have started cleaning the blocks thanks for info on book i will be back these foruns are great.. thanks again.
