Blooming gelcoat!!
damie
Does anyone know i can regenerate my gelcoat?<br />it is a deep burgandy colour.In the sun it starts to go a pinky colour..i polish it and it lasts a few days...then pink again..<br />any ideas?<br />thanks.
Re: Blooming gelcoat!!
Paint,......... That's about the Best Option out there..........
BillP
If compounding and polishing doesn't do it...break out the 600 grit and sand away, then compound and polish.
Yacht Dr.
what Bill said..it sounds like your not rubbing it right..ruba..and rub again...dont use cheap ( use this polish once and get perfect ) put some Rub into it :)
damie
Update....i have cut back with cutting paste and mop and now have a good shine, how can i keep it that way?<br />can you recomend a good polish?.<br />Thanks.
Realgun
You want wax not polish! polish is like sandpaper wax is a coating to protect it from UV and bird doo.
bounder4465
I think this question was asked before in your eariler thread without a response from you. Can you use a buffer?
