Bluedevil hydraulic leak plugging liquid
Didn't go look at the link (never know if some kind of male ware is there) but I'll say, I have found nothing that will fix a leaking seal for very long. So things are able to add something which will temporarily slow of stop, but it doesn't last
Grub54891
Band aid in a can, As dodge stated, it MIGHT work for a bit, then fail again. best to rebuild what you have, or buy new......
Ayuh,.... Don't do it, fix the Problem,....
I live in a Hydraulic world,...
I'm a heavy equipment mechanic in my day job,...
achris
More fish than mountain goat
3,000psi is not to be trifled with. As already stated, fix the problem properly, not half-fast....
We use water under far less pressure than that to cut steel plate, underwater!
Chris.......
