boat cap installation
DUNK51
what would be the best thing to use to seal between hull,cap, and rub rail?
gm280
How did you take it off? Were there screws, rivets, glue or what? That would be the best idea for reinstalling it. If the rub-rail insert covers over the seam, then any of the above fastener ideas would work...
If it's a bass boat and sits low, silicone would work but IMO 3M 4000 would be a better choice
DUNK51
yes terry bass boat is correct, its been a long time :rolleyes: maybe two years. but if feels like I am getting close. thanks for the info:)
Woodonglass
Lot's of times you don't need to use anything. If it becomes a problem, I'd use 3M 4000 on the problem areas only.
