boat fuse panel
hieufolifeaz
so i have a boat that have a glass fuse panel . Can Im upgrade with a fuse panel without the glass fuse ?.Does is work with the boat or not ? . Thanks
matt167
Yep. Looks like you have an older 6 circuit blue sea systems. They make an ATC fuse block that will wire the same. It might even use the same mounting holes.
Not sure I would classify swapping out one fuse type for another as an “upgrade” but it will work.
