Boat hp limit question
nutdpl
I purchased a '68 Aerocraft 15ft trihull, it came with a '62 75hp evinrude, I found the capacity plate and it says 70hp max, Is this going to cause an issue legaly??
Re: Boat hp limit question
Depends on the laws of the state you are in.
In Wisconsin, and some other states, it is illegal to power a boat in excess of the rating plate.
Check your state's boating regulations.
NYGiants
also a motor of that age, its true hp rating is probably closer to 70hp. but then again the makers accounted for 70hp motors rated at the power head
