boat leak
rwcreigh1
hello i have a tracker 1983.ok the ribbits and the seems are leaking(i have a bilge pump and it works hard)somone put somthing grey maybe jb weld on all ribbit and seems years ago.i want to scrape off most of the grey stuff and put somthing to slow the leaks but what?what would you use ?thanks
Boatist
Re: boat leak
Best way is to tighten the rivets you can get to. Hardest part is to find the leaks. some put water in the hull and mark all the leaks you can find. Any leaky rivets you can get to both sides of use a backing hammer under the boat and tighten from the inside side. You can get a die that fits the head but if you are gentel can tighten most with out the special tools. The ones you can not get to are harder to seal.<br /><br /> http://www.iboats.com <br />search for ALUMINOX PUTTY<br /><br /> http://www.cabelas.com/ <br />Then search for Rivet repair
crazy charlie
Re: boat leak
Thanks Salty,I needed a good laugh.Thats exactly my kind of humor!!! OK Richard back to your ribbets.Get a wire wheel and clean the ribbets off as good as you can.Wipe with acetone when you are done and apply a nickel size dab of 3m 5200 sealant.Wet your finger and smooth the edges .Do this and your ribbets will leak no more.I did a 25ft cabin cruiser some years back and it stayed dry as could be for years.Charlie
jtexas
Re: boat leak
Originally posted by crazy charlie:<br /> ...Wet your finger and smooth the edges ...
If you wear contact lenses - put on some latex gloves first! even hand washing can leave some residue behind. It Hurts!
