Boat Weight ?
shooter26
Hello, Iam looking for the approximate total weight of a 16 1/2 foot Crestliner FishHawk with a 12 gallon gas tank, Merc 40 Tiller, 2 Batteries, 3 seats and Trolling motor.<br />The year of this boat and motor is 1995.<br />I need this information so I can buy the proper aluminum boat lift.<br />Thank You for your input in this matter.
Re: Boat Weight ?
I have a similar boat and would say you are about 1200#. Could be a little less, or as much as 1500#, depending on contents. Possible 2000# with people and coolers etc.. I would go larger if possible. Someday you may get a heavier boat.<br /><br />One thing to think about. You should be covered if you buy a lift with approximately the same weight rating of the trailer.
