Boats from work.
MikeSchinlaub
Oh, we're also doing 5 factory fresh 2026 Cobalts, $250k+ boats, that had scratches, cracks, spot ins not sanded and buffed, and just crappy buffing. The marina ordered them for a boat show next month and found lots of problems. One is all black, so it shows everything.
One is already done and gone.
MikeSchinlaub
Ikon was moved into the wash bay yesterday to wait for a few parts. I started on a small spot on a waverunner, and one side of the trim for the overhead door was coming off so I had to screw that back on. I hate philips screws, stripped like five of them.
MikeSchinlaub
Productive day yesterday. I sanded and buffed the waverunner and put it back together, then started on the Ranger I'm doing next. Geound, glassed, took some stuff off, and got the lids ready to take off. Just a few screws left to hold then until I get some help this morning.
Then I went home and was replacing all the insides of the toilet tank until about 9:30.
I have to say you have a fun job. Being able to do different stuff on different water craft all the time is a plus for keeping things fun. Would be for me anyway.
As for the toilet tank repair I’d take that over dealing with a macerator pump any day.
That was my Sunday morning joy. Someone has been flushing rubber gloves down the toilet and they jammed up the impeller. 🤬
MikeSchinlaub
We have one at the shop. About 10 years ago, there was a guy wiping with and flushing paper towels down the toilet. Boss said it clogged it up.
Who would flush rubber gloves anyway?
Right I mean there is a trash can right next to the toilet. I have my suspect in mind but a few people wear them so everyone was warned that I’m not the one going in next time.
MikeSchinlaub
Doing the flake on the Ranger now. This time, instead of blacking out the bodywork under each color as I go, I gelled the whole spot yesterday so I could just sand it and flake over. I don't know why I never thought to try that, I was just taught to do it the other way and always did that. This really makes the whole process a lot easier.
Also, remember that Razor the guy next to me is working on? Well here are those pvc pipes that the wiring is routed through.
Great idea, but there's no drain outlet. At least the one running to the back with the steering and other wiring opens up and can drain. Even if you would drill a hole now, it's just going to go into the foam.
And what's with the plastic around the gas line?
It's not going to help much if the line needs replace. The foam expanded around it, so it's still going to be pretty well clamped in place.
"Razor Boats, good ideas, bad executions."
MikeSchinlaub
I finished the Nitro yesterday, Including a spot on the rear starboard corner of the deck which I forgot to take pictures of.
Also finished grinding, glassed, and did some bodywork to the Skeeter.
MikeSchinlaub
So far this week I've black gelled the area, sanded it down, and am now masking to do the flake. The flake isn't expected to show up until tomorrow, and if it isn't early in the morning I won't spray yet. The blue gel is expected Tuesday.
In other news, the new guy was drilling through the dloor of a Nitro and hit the gas tank. That's gonna be a lot of work to replace.
MikeSchinlaub
The floor is mostly in the Razor, just the front most piece left. Whoever designed the stringer layout doesn't know how to use a tape measure. No two boards landed their edges on the same stringer, stringers were different heights, this thing is just poorly made. The front has probably about a 1/2 inch void just filled with putty because of the uneveness.
These two on either side don't even sit on stringers, just the hull and little ledger pieces under the adjacent pieces.
Every clamp of the shop's, supervisors, coworker's, mine from work, and four more of mine from the house.
