fbriggs
- Joined
- Mar 30, 2017
- Messages
- 25
motor 2010, 60hp 4stroke efi sn#1C113678, is hesitating bad at throttle up. No power and dies if you bring rpm from high 5000 to idle. 1st pump holds 5-6 psi constant, high pressure pump only holds 30 psi constantly.
I'm suspecting dirt in svt screens, pump or weak fuel regulator. My big question is will a low (30) psi create these problems.
