Bolting on new coupler
Silverbullet555
Well the road to hell is paved with good intentions.
The plan was to bolt on the new coupler using the old holes and drilling one more hole.
That all went to hell when I went to mount it. There is a gap between the top of the frame and the coupler.
That washer measures .085" so the gap is .10".
Can I bolt it on or does it need to sit in direct contact with the trailer frame.
If it does, I will have to move it back about 2" so I can drill new holes.
Or, can I get a piece of delrin, steel, aluminum, etc to slide in between.
If it matters, the rectangular tube is 1/8" wall 3"x4" and the bolts are all grade 8. The plan is to use crush spacers inside the tube to prevent any crushing of the trailer tube or tongue when torquing the bolts down to their proper spec.
Help!
smokeonthewater
Re: Bolting on new coupler
It'll be FINE... If in doubt tho.... get a piece of 1/8" flat stock and shim it
Silverbullet555
Those are words I love to hear. I will drill today and shim tomorrow before we head to the lake. I wanted to get the hole drilled so I can paint the edges to try to limit rust.
Ayuh,... I agree,...
Shimmin' it is good, the bolts hold compression on the sides of the tubing, not the top...
