- Joined
- Mar 18, 2009
- Messages
- 15,097
That last sentence is your winning ticket. Make friends, bring him Scooby snacks and beers.
I like that idea!And don't by everything you think you need all at once. Gives you reasons to go back and ask more questions.
Why does more need to be removed? All the wood is out. The areas to the left and right of the transom are just one layer of fiberglass. If I remove them, then there is no stern.Those other areas left and right of transom and higher areas need to be removed.
Save all the skins they can be used to place back. Saves a lot of glass work.
Looking good. And shop/compare pricing
To me looked like the glass was fractured.Why does more need to be removed? All the wood is out. The areas to the left and right of the transom are just one layer of fiberglass. If I remove them, then there is no stern.
There is no wood to the left and right.... just that area in the middle that is already cut out. Only a layer of fiberglass is to the left and right. No wood.I cannot tell if these areas are compromised. I would suspect it has wood in there.
Need your help guys... working on the motor today... compression is 105...105.... and 65 on the top most cylinder.... got the head off. doesn't seem like a gasket issue. Gasket Seems intact. But have a look and advise away.
Also... last night when I tried starting it up.....I got it to somewhat start and then it died..... it never got to the point where I could stop turning the key and keep it running.... today.... it wasn't as successful. Revelation up a little bit.... stopped and then the starter got hot and started smoking the longer I kept the key turned... so I stopped... funny thing though.... when.I got the head removed....I fired turned the key... knowing the engine wouldn't torn over.... but I wanted to see what the pistons did.... and all of them started moving continuously and without any sputtering or stopping like it did with the head on.... is that normal? Wish I could attach videos on here from my phone.
Top cylinder looks definitely questionable. What kind of repair am I looking at?
Nope... not at allNo love there! Doesn't appear you're afraid of work anyway.
It's not a force... it's a Suzuki..... but I am thinking the same thing... not afraid to spend that kind of money though..as long as I get a working engine out of it whether or be to bring this motor back to life or spend that much for a working used one.If that's a force outboard, I'd say stick a fork in that powerhead and call it scrap metal. I'll give the details why below on the damage I see.
Force engines becoming ever more difficult to obtain parts for key items.
You'd probably be better off looking for a 1981/1982 and up V4 crossflow or maybe a evinrude/johnson 3 cylinder looper (not sure of the best year model ranges for that)
As regarding powerhead condition description based off of photos.
Top cylinder looks like it ran lean and detonation/pre-ignition happened.
Having damage on the edge of the crown of the piston on the exhaust side is usually points that the likely failure point was detonation/pre-ignition.
You will likely end up nickel & diming your way to $1700 worth of machine shop labor, powerhead shipping, and parts. Definitely NOT worth it for that outboard.
As mentioned previously, parts support is the biggest concern.It's not a force... it's a Suzuki..... but I am thinking the same thing... not afraid to spend that kind of money though..as long as I get a working engine out of it whether or be to bring this motor back to life or spend that much for a working used one.
