Bravo 1
asgrinne
New to us boat end of last season. Noticed some clear 90wt coming out of top half of stern drive. Can't realy tell where it is coming from. ANyone else run into anythin similar?
Re: Bravo 1
You'll have to Much More Specfic......<br /><br />Where on the top 1/2 ????<br /><br />Any Leakage is a Problem......
Re: Bravo 1
You shouldn't be using any clear 90W in that drive anyway. Use the Merc Hi Performance gear lube. Your drive has a cone clutch and that 90W is the wrong thing.
asgrinne
Re: Bravo 1
Thanks and sorry.<br />I am not sure its 90wt it appears to be similar.. Sorry again. Its appearing on the drive where the Bravo 1 wording appears. <br />Will check it out better this weekend..
