Bravo 3 Fluids Help
thedukeryan
I need some help with getting the right fluids. Need hydraulic trim fluid, power steering fluid, and engine oil. First off in the past I have used powersteering fluid for both the trim and power steering? Also what weight for the engine? And lastly this is what really has me guessing. There is a small resivour on the captains side of the engine across from the power steering. It is a clear container that I think is for lower unit lube. This sound right? If so what lube? I got some extra 80-90 is that right?
Re: Bravo 3 Fluids Help
Ayuh,.... Trim,+ P/Steering can use the same oils... Hyd. oil or ATF....
For Motor oil, consult the manual, or run Whatever you'd like...
The Outdrives live the longest with a Hi-quality Syn-oil in 75W-90...
