Bravo II after the loooong storage
fishaman
Hi all,
I have just acquired a Bravo II which is great cosmetically from all sides including shaft entries' areas, and shafts themselves. No signs of corrosion. The drive was stored in a heated garage for at least six years latched to the wall at about 45 degree from vertical position with propeller shaft pointing up also at about 45 degree angle. When it was still attached to the wall, the gear shaft was turning smoothly and easily in neutral, but in the same neutral gear I could not turn the prop shaft by hand (no prop was on it). Unlatched from the wall, the drive showed a ton of dust on the hidden side, which somewhat proves the long storage story from the owner. After it was layed down on the floor, I tried to turn the prop shaft again in a better position, and after several tries it turned, but what a sound it made... as if I am turning the giant coffee grinder, or some dry sandstones turning against each other in some ancient mill. With each turn it got better untill it settled at a pretty smooth rotation, same as any other working drive I've seen.The drive was ful of oil, it probably had spread around when the drive was laying down.
So... should I be worried? Worst case scenario is that there was some water in the drive that settled down in the cone when the drive got immobilized for years, and rusted the bearings. But I drained the oil, and did not notice any light streaks, all was dark green (but not new, the oil obviously had not been changed before storage).
I will pressure/vacuum test the drive now with no oil in it. Should I still pull the carrier to look at the bearings, or is it normal for the prop shaft to dry, lock up, them make a grinding sound after long storage?
Any shared experience will be greatly appreciated.
Alex
Re: Bravo II after the loooong storage
do a pressure test with no lube in the drive
during the pressure test turn the splined drive shaft clockwise while pulling outward on the shift linkage with a needle nose pliers
this will engage the shift yoke with the cone clutch and the prop shaft should begin to rotate while still turning the splined shaft
continue to rotate several times, then push inward on the shift linkage to the neutral detent then again to the next detent
the propshaft should now rotate in the opposite direction while still turning the splined shaft clockwise
this will show you that everything internally is working properly, as far as gear/bearing condition the only way to know for sure is to disassemble, clean and inspect - if you do that you may as well reseal the whole drive
TilliamWe
Banned
I don't think you're supposed to turn Bravo drives' props when they are off the boat.
fishaman
Thank you for your replies, I will continue checking. Without pressure the drive turns and shifts properly, so I am mostly concerned about some inside rust happened during storage. Probably will disassemble at least the lower unit to check the bearings and replace prop shaft seals.
