Breather Tank Fab and Tool modifications.
TJS
Don't ya just love it when a plan falls apart. Man, crazy s&&t. Anyway, I have been asked to make a puke/breather tank like mine on my Nordic Jet Boat. The wierd thing is this person has the same make Nordic.
Found some nice 6061 tube and made a drawing from mine on my boat. While I was fishmouthing the breather upright tubes on my Bridgeport milling machine the hole saw adatper broke when a tooth caught. Great, now I pull out the tube notcher I never used because I just use the mill for fishmouthing. The threads are different on the shaft for my cheapie hole saws. I know, I will adapt the broken part to the shaft. My lathe does not have threading capabilties otherwise I would have threaded the tube notcher shaft. Sooooo, I made the hole saw adapter fit the tubenotcher shaft. It made it a litte long but some angle and good to go. Just have to get some fittings for the end and weld it togehter. I will be using Moroso breathers. This will be for a blown big block ford Jet boat. A little bit of creativity to get the thing done. This is not my profession, it is just a hobby, I work at a Bank.:D
T.J.
TJS
Re: Breather Tank Fab and Tool modifications.
Cont.
TJS
Ok more pics. I don't use -10AN specific weld in bungs because they do not have a deep enough reach on the backside. I turn down the NPT side and soak them in oven cleaner to remove the blue anodizing.
Also notice the angle welded on the inside of the end plates. They are my baffles. I have them oriented vertically so when the oil hits the angle it drops out of the flow and into the bottom of the tank. I have to also weld a drain in this one. As you can also see, it is all about Jigging this right to get a good weld.
T.J.
TJS
T.J.
Doing what? Building the vaults? :)
OK, what is a puke/breather tank ?
TJS
See pic. This is my Oil Breather/Puke Tank.
ajgraz
Purdy stuff. You going to intercool that blower? Does that even make sense on a boat, I wonder?
redone4x4
Who has a bridgeport in their garage???:eek: thats pretty darn cool in itself. neat looking work.
Sharp Shooter
Nice work!
A brand new Mooneyes 2 qt puke tank is $245 :)
OK, makes sense now, very nice.
You are an artist.
Kiwi Phil
You work in a Bank!!
Something doesn't sound right here!!
wow..that is very impressive...just not what I'd expect from a bank-johnny in a suit.
Cheers
Phillip
(PS, you don't want to move to Australia and work in a Nursery do you??)
