Brightside paint question
mech1521
When spraying brightside one part polyurethane, do you: A. Apply 3 heavy coats, carefully remove tape, wait till next day and sand smooth with which grit? or B. Apply 4-5 thinner coats, keep tape on, and sand lightly between coats with which which grit? or C. sell it as is(just kidding) I've come way to far in this project1984 Imperial 072.jpg1984 Imperial 071.jpg
Re: Brightside paint question
Ayuh,... Regardless the brand of paint,...
I do a once over with a light coating, followed by a 2nd coat to cover...
The 2nd coat goes on, as soon as the 1st coat tacks up...
No sanding at All...
