British Seagull Silver Century acceptable compression
todd281
I just came into this Silver Century and have a few questions about it. It is mostly intact but is missing the carburetor . Before I purchase one and have it shipped from overseas, I would like to know if it is salvageable. I did a compression check, and came up with 50-60 lbs. [keep in mind that with the big 18mm plug my regular screw in compression gauge would not work. I had to resort to a hold on/in the plug hole type while turning the flywheel with a cordless drill and socket.] I did the test a few times but do not have the greatest faith in those type of compression testers. So whats the call? enough compression to run? {just get my hands on a carburetor] or not good enough and part it out? The rest of the Motor is in good shape, good spark.
or bore and hone and new pistons.......
my guess is someone didnt like the way it smoked and ran it on 50:1 vs 25:1 and now it is in need of a rebuild.
consider it a project or consider it wall art until you get it, tear it apart and restore it. I seriously doubt it would be a put a carb on and run motor
todd281
thanks for the advice, how much compression would be acceptable?
F_R
I've never seen a Sea Gull that wouldn't run. Well maybe being missing a carb might do it. I'm betting your 60 PSI is fine.
