broke a courtesy light cover
cooleyo
Any ideas on where to get a replacement cover for one of my courtesy lights? While washing the boat, I tossed the hose toward the rear and the nozzle busted the light cover. Its a small clear oval shaped lens. I've had no luck finding the same style, and would like to replace in kind as opposed to having one different from the others.
cooleyo
Re: broke a courtesy light cover
Thanks for the reply. I have googled it, but after looking for maybe an hour I gave up. Was thinking maybe someone has dealt with this issue already. I haven't tried Hurricane yet. I bought used, so have never dealt with them, maybe its time. I'm not used to having to go through a dealer to get parts.
pbolden
All Hurricane will do is direct you to a dealer in your area which might not be helpful or to your advantage. I've had to get a number of parts over the last couple of years. Here's a hurricane dealer that I found to be helpful as well as having the lowest prices for parts that I've found. This should at least get you started.
TOMMY HELTON
RUSSELL MARINE
334-857-2111
Good Luck,
Paul Bolden
Just another thought . . . if the light assembly has markings on the back of it as to the brand and/or part number, that can lead you to a source. I've done that with various items on my boats and have been able to find what brand/model of component the boat manufacturer used.
cooleyo
No, not the same, but thanks for the effort. I guess it would help if I posted a picture of what I need. Gonna try and get a part/model as Ted suggested. I will give the search a couple more days, then try the dealer Paul suggested.
NelsonQ
Cooleyo
Gotcha.. the one I sent was what was on my 2002 Hurricane, the one you show matches that of the light on my current Hurricane.
If you called Hurricane directly, I suspect they could provide the specs on it (manufacturer, etc) however I've not seen that aftermarket and you'd most likely have to get it from Hurricane via an authorized dealer.
