Broken bolts in L U
Spin 53
Hi everyone,
I snaped the hiden bolt in the lower unit, (the one in the snout).
Can I run the engine, or will the viberation be too much for it to handle.
as always thanks for the input.... Spin.
(Btw This is until I re-tap ..... all my drillbits are junk)
This is a 125 Force 1985.
Re: Broken bolts in L U
You can try it, IF the snout is still in place.
Without the snout, the exhaust will go into the prop, and ventilate.
Spin 53
thanks Rosco.
Tried it and it stayed together..
Spin.
