Building a fishing boat.
metalchewy
Since the last post, made a lot of progress. A whole Lotta sanding. Then applied gluvit down the seams and on every rivet.
The next week, scuffed up the gluvit, etched, washed with simple green a couple of times and applied zinc chromate primer.
Last few days, Scuffed up the primer and put fairing compound down the seam edges and partially filled some dents. Then sanded the compound, added more compound to finish the dents, reprimed the areas that had fairing added after sanding.
Ready for a final scuff and paint. It's not perfect, but after the enamel and then epoxy paint base and top coats of epoxy paint any flaws will mostly dissapear.
metalchewy
2 coats of rustolum topside enamel. Will be a good base for the white gatorglide.
I know GG is expensive, but with the conditions at the lake, dropping 1-2 feet a week, with new rock hazards on every trip, it will be worth it. The unseen rocks cause worry. A lot of sunken boats out there.
Even trolling in the canoe, we've seen it go from 30ft to 4 feet within a 10 seconds. The fish finder helps map the bottom, but the canoe doesn't run at anything more than 4 mph
A strong slick bottom, with the hardened gatorbase and G2 will help give some peace of mind, for bouncing off vs a hole in the bottom.
Building it to last..
jbcurt00
Glu-vit is typically applied to the seams amd rivets on the inside of the hull...
mr 88
I'd be looking for a 30-40 mid to late 60's Johnson/Evinrude, easy to work on and parts are available. I have not heard one good thing about a Force engine and 50 is too much for a 14' aluminum hull to begin with , unless you've re-enforced the transom with angle braces .
metalchewy
If the outer hull is down to bare metal down the rivets and seams, there are no issues applying gluvit to the exposed rivets and seams prior to painting an aluminim boat. Yes, if leaking, people usually apply it to the inside, but why not seal it where the water comes in, versus the inside where the water pressure is higher?
Also, We do have another quart for the inside seams an rivets, once we get the boat flipped over if for the seam from the gunwall to the bottom, for overkill.
metalchewy
Thank You, I appreciate the input. I actually have a Johnson 30, out of a 71 boat in my dad's shop a state away. It's the other option we have. I just need to get it here. Dad wants it gone, just need bring it back on my next trip up there.
It's a lot heavier than the force in my garage, which from what I've read ithe force is closer to 40-45 horse based on some of chrysler's inflated numbers.
The Johnson certainly has a bigger prop on it. It's gone thru two owners (1999 and 2024) before it landed in my hands, so haven't had a chance to asses it yet.
Planning a trip up there to bring it home in a couple weeks.
mr 88
The prop should be matched to the maximum rated RPMs of the motor. Ex , motor rated for 5,000 rpm and all you get is 4,400 which means the motor is working hard , using more fuel and shortening its life . The prop has too much pitch in this instance. You can buy a cheap tach online that'll do the job if the boat doesn't have one .
metalchewy
Thanks for the suggestion.
The boat came without a dash or steering wheel. Looks like it was removed a long time ago.
Have a wheel and linkage, throttle, wiring and switches for lighting, kill safety, etc that were in the boat we pulled the engine from.
Planning for a couple of guages (Voltage and RPM) for the dash we are going to build. Fish finder will have speed, GPS and compass on it.
metalchewy
@mr 88 your post prompted me to look at guage sets. Will plan in a 7 guage set for the dash we build. A lot of nice looking inexpensive sets out there with GPS speedometers..
metalchewy
An update. Still moving along. Dash, wiring, fuel lines are all that's left.
Fully painted, after flipping it. Floors cut, treated with PU and carpeted.
Engine and sterring mounted.
Seats mounted, and console added.
Getting closer. Still working on the dash, a couple more holes.
Looks like you have been busy over the winter. Splash should be happening soon!
Looks good
Have lanyard kill switch attached, and do you have a way to get back in the boat if you fall out?
metalchewy
The
Looks good
The Two holes left to drill for the dash are the lanyard kill switch and the ignition switch.
Good point on adding a step to the back of the boat to get back in. Will add it to the list of things before finished.
The
Not something most folks think about until it happens ! On my 16' I leave a small loop of the rear dock line hang over the side a few inches, enough that I can reach it from the water, but not enough line to get tangled in the prop. Between the line and the power trim, I can raise the engine with me on the cav plate until I can crawl in the motor well.
Sounds crude and difficult, but it really isn't that bad. If I can do it at 74, you younger guys should be OK. Bigger boats will require different thinking...
