building up marine tex ?
salmonee
I'm trying to build up the keel section of my boat with some marine tex. Do I HAVE to sand between layer?
Re: building up marine tex ?
Nope,... Only if you want it to stick Properly....
saildan
I'm trying to build up the keel section of my boat with some marine tex. Do I HAVE TO sand between layers?
I know the instructions are complicated and hard to follow, so in a nutshell, yes.
How to prepare surfaces for bonding:
-Remove all rust, scale, paint and loose materials from the surface.
-Clean all surfaces so that any dirt, grease, oil, wax, etc is completely removed. (Lacquer thinner or acetone are excellent cleaners for many surfaces.)
-Sand a profile into the surface with 80-100 grit sandpaper to abrade the surface and provide a 'texture' for a mechanical seal.
-Wipe with solvent once more to be sure sanding dust hasn't contaminated the repair.
-Please DO NOT use soap! Soaps and regular detergents leave behind a residue that can cause a problem with adhesion.
http://www.marinetex.com/Marine-Tex_how_to.html
http://www.marinetex.com/ContactITW.html
:rolleyes:
Just be cautious since marine tex should be used along with maybe some fiberglass epoxied over the top as a layer. That will help in building things up.
How much build up are you trying to achieve?
