Burned out points
msmorto
Hi:<br />I have a Bayliner with a VOLVO AQ125 4 cyl engine.<br />The boat run very well for about 4 to 5 hours, and then it start to<br />miss, I though that I had a fuel problem but it was not the problem.<br />After replacing the points with new one, the same thing happen <br />It run very well for 4 or 5 hours and then the points burn again<br />ANY IDEAS ??<br />Thanks<br />Mario
Re: Burned out points
Too Much Voltage ??????<br /><br />Wrong Coil ?????<br /><br />Resistor Not resisting ??????
KaGee
You should have approx. 9 volts on the positive side of the coil. Any more than that and you burn up the points. Resistor wire could have shorted allowing 12 volts plus. Or you could have a voltage regulation problem allowing too high voltage on the system.<br /><br />You'll need a volt/ohm meter to track it down. Don't rely on your voltage meter on the dash.<br />Good luck!
msmorto
Thanks Guys<br />I think that I have the wrong coil, I will<br />replace it with the correct one next week, Hope this will solve the problem .<br />Thanks<br />Mario
Scaaty
Pretty sure its the coil...mine just went bad too.
hoot
any condensor with these points? replace it too!
