Cable Adjustment - long travel
harojs
Replaced my shifter and throttle cables on VP 5.0L SX drive, Seastar Universal Control. Much easier to move now, however, I have to move control quite a bit forward or backward before SX drive engages. Was like this before cable change also.
[Q] Could tie wrapping cables more to underdecking reduce this slop? Seems like cables move around a bit when engaging. Or, should I play with cable adjustment at SX end?
John
La Conner, WA
Grub54891
It's possible the cables are to long, however if you secure them to the hull it may take out the slop.
