Calculating prop size for sailboats
Status
Not open for further replies.
smasterson2
I'm currently working on an electric saildrive of my own making. My intention is to start with a product best suited for daysailers. I hear a lot about how prop diameter for sailboats that "the bigger, the better". My understanding is that the prop size and pitch should make it possible to spin the motor at the right RPM to maximize the motors top end power. Not too slow so to avoid overload and not fast as to overrun the motor.
​The thing I want to know is should I use a prop that is best suited to match the motors max power or should I go with an oversized prop with maybe a reduced pitch?
​If this helps, the sailboat would typically be up to 27ft and 5,000 pounds. The idea is not to push for hull speed but more likely 4-5 knots so as not to have to push water.
Thank you in advance.
Scott
Take the engine's gear ratio (drive shaft RPM vs. prop shaft RPM) and relate that to the propeller pitch to get your 4-5 knots of speed. Then size up the diameter to match the power of the engine. Net result is that the bigger boats, needing a more powerful engine, will have a larger diameter prop.
Factor in about 15% prop slip to the pitch, for reality purposes.
Keep in mind that on smaller sailboats (20 ft range) 5 knots is going to be at or slightly above the hull speed of the boat. In reality, you may also want to increase the prop pitch slightly on a bigger boat in order to match the greater hull speed.
Also keep in mind that an electric motor has a different torque/power curve than an internal combustion motor (engine), as far as determining the best top RPM to design towards.
understand your market
if the sailboat is used for any racing, it needs to have enough power on board to get to the farthest point of the race and back without wind and being too heavy
there is a reason most sailboats have a 4hp tohatsu / Nissan / suzuki / Merc etc hanging off the back to get them from their slip out to where they can hoist the sails. it weighs next to nothing with fuel in it and can be removed to move down below for the race.
those two factors alone are why most of the sailors that I know wont ever use electric. the weight of the electric motor and the batteries, etc is too heavy, and the amount of weight needed to push the sailboat 25-50 miles is too much of a weight hit to the boat. These are guys that have switched all their lights to LED's and gone away from group 24 batteries to two SLA-12v 10ah batteries located center near the mast so as not to affect balance and because it saved 26#
there are people that would look at electric. they want to completely unplug - however your talking 35-50' live-aboard boats. your going to be hard pressed to match the 120hp Yanmars they have or the range of a tank of diesel when going down to the bahamas
FYI - talking to the people at the yacht club. a 2-stroke 4hp motor is 27#. an electric trolling motor is about 27#, then they have to have a 45# group 24 battery. that weights too much for regatta racing. the 4-stroke 4hp motors weigh too much
one guy has a 20# sears game fisher that everyone keeps wanting to buy
Sea Rider
J24 sailboats for regatta racing are equipped with 2 or 4 strokes 3.5HP motors, being the 2 strokes the lightest one. You should prop right any outboard to run to max wot rpm factory stated as usually loaded, for that task will need to install an induction tach in order to play with same diam less prop pitches.
The sailboat will have a better fast displacement speed at reduced throttle setting than using the same motor with medium pitched factory delivered prop at a much higher throttle setting along more fuel consumption, we're talking about standard portable motors, not sail ones which are delivered better propped.
Happy Boating
GA_Boater
Talking to a stone, the OP has been gone for 2 years.
Closed until he comes back, if ever.
Status
