Can 2 batteries cause boat to list
lrlima
I have a 23 ft cuddy boat with a 5.8 engine. Swimming behind the boat today and boat definitely lists to Starboard side. Nodody else in the boat and no heavy gear on board. I'm pretty certain gas tank is in middle of boat. Boat also lists while underway, especially when it's just me in it. I would say its about four inches lower than the port side if I had to guess.
I have both batteries in the back starboard side of the boat, but I would be surprised that two batteries could cause that. Conversely, this boat couldn't be waterlogged.....always been a covered trailer boat, has a fiberglass floor, and jumps out of the hole.
Eventually I'll take them out and see for sure, but it will be a while until I can do that. Any input is appreciated.
CaptainKickback
Re: Can 2 batteries cause boat to list
Of course every weight has some effect, but I can't imagine the batteries having a noticable effect.
Sea ya...
jestor68
Since a good sized lead acid battery can weigh upwards of 70-75 pounds, that would equate to having the "average" size person sitting on the right rear corner of your boat.
My battery and power trim pump are on the port side. When I sit at the helm(starboard side) it evens out the weight and the world is perfect again. :)
partskenn
My SeaRay 268 would list to starboard until I filled the fresh water tank. It held 20 gallons, or around 140 lbs. Then it would sit nice and level.
Augoose
My 20' BR lists slightly towards the side w/two batteries so I make the wife or kids sit opposite!
Home Cookin'
not a boat that size. but it's certainly easy enough to test; disconnect one and put it on the other side. Weigh them and put equal weight on the other side (I didn't think batteries weigh 70# but I don't know).
Is your bilge dry?
The fact that it runs with a list says to me something else is amiss.
spoilsofwar
Large deep-cycle batteries can easily weigh 70 pounds or more... The Diehard Platinum second battery I added weighs 53lbs, and that is the small, group 34 size. The group 31M size version weighs 75lbs. I installed my second battery on the opposite side of the boat as the first for this exact reason.
Anyway, I agree that a battery, even a big, heavy one, should not cause a list on a boat that size. But, as stated, pull the battery and put it on the other side to see what happens.
lrlima
thanks for the replies. To answer and comment on a few of the responses....
Yes the bilge is dry. I would estimate that the batteries weigh 40- 50 lbs each. Also, the boat has a fresh water tank on the opposite side (which is currently empty). I wonder if the engineers have it that way assuming it would balance out the weight if full.
I asked my wife approx 120lbs to stand on the opposite side swim platform and the boat evened out. Going to take one of the batteries out when I get time next week since its such a PITA. thanks again for the replies
BoatDrinksQ5
yeah i would think in designing a boat that they would account for a full or at least half full of all tanks... gas , water, livewell.
Otherwise if you put the boat into full service...and all tanks were full and on one side - danger in rough seas.
^+1, or keep the wife on the swim platform.
if your fresh water tank is 15 gallons, that is just shy of 120#
CaptainKickback
Hey partskenn. I'm surprised to hear the 120 lbs made such a difference on a 27' boat. Had a Cruisers 2870 with 10' beam. It made no difference when several people changed sides. It was not a deep V, but I think yours is.
My current project boat is a 1981 Sea Ra SRV 255. Deep V. I'm planning layout now. Maybe I'd better wait on some things until I get her on the water.
Sea ya...
TilliamWe
Banned
I asked my wife approx 120lbs to stand on the opposite side swim platform and the boat evened out...
And you obviously got your answer. It's the batteries.
If you don't plan to use the water tank, move the batteries to that side ands leave them there.
Thalasso
Is your bilge dry?
Was thinking the same thing. It would take two people to install Batt.
Interstate Batteries.
Group 27M cranking batt.=54lbs
Optima Group 31
SC31DM =59.8lbs
Deep cycle/cranking group 27 =55lbs
partskenn
Sea ya...
The 268 was an 8.5 beam, water tank was up against the hull running lengthwise, so I guess all the weight was as far from the centerline as possible. But it was dependable, every year we would put it in the water, look at it from the stern, and my wife would say "better fill up the water tank", and it would visibly change.
spoilsofwar
Optima Group 31
SC31DM =59.8lbs
Diehard Platinum group 31M
http://www.sears.com/diehard-platin...p-02850131000P?prdNo=1&blockNo=1&blockType=G1
Item Weight (lbs.): 75
Odyssey 31M-PC2150 (basically same battery as above)
http://www.odysseybattery.com/marinespecs.html
Weight lbs (kilos) 77.8 (35.3)
I know these aren't the OP's batteries, but just showing that marine deep cycle batteries can weigh that much... The weight can be a sign that they don't suck, like Optima's do... But that's another discussion.
I'm surprised that such a small weight shift could affect such a large boat, but, I didn't really consider hull design, and being a deep V it seems plausible.
