Can Anybody Help Me 120 Hp Force
Jasper8301
I need to know if 1986 force 125 hp can interchange parts with a 1991 120 Hp. Force engine...
Re: Can Anybody Help Me 120 Hp Force
Depends on the specific part.
F.O.R.C.E.
If you compair the part# from both motor years and they match, then it should be o.k. to swap.
moparman
I know the bore and stroke are different so that knocks out the crank,rods and pistons,so that doesn't leave many hard parts to work with,not sure about the coils and cd units, they probably will, but check part # first to be sure, same on the trigger. moparman ROLL TIDE
