Can I take out my Thermostats?
Johsnson Outboarder
Seems like taking out my Thermostats would keep my engine cool with no risk of ever letting it get too hot. is it safe to take them both out and run the boat like that?
Nope....running a 2 stroke under operating temp creates a whole different set of problems
Johsnson Outboarder
I see. Is a broken Thermostat capable of shutting off spark distribution? My engine shut off after 20 minutes on the water. No spark at all until it cooled down in my garage.
Vic.S
If you suspect that a defective thermostat is causing overheating you can test them by slowly heating them while suspended in a container of water with a thermometer as described in the workshop manual. They should start to open at 125 F and be fully open at about 140 F
F_R
While it is possible, it is really rare that thermostats fail in closed position. Almost always fail in open position.
Johsnson Outboarder
Good to know, thanks! They're $13 each so I ordered them. Anxious to try but definitely staying close to the boat ramp the next time I launch.
Vic.S
You have ordered new thermostats without inspecting , checking or testing the existing ones ?
Johsnson Outboarder
I checked the thermostats when I removed them and the pin that extracts fell out on both of them once the water got hot enough for them to come out. I didn’t want to take a chance and leave them in there since they’re so inexpensive. I doubt they’d been replaced before.
