Can someone help me find an owners manual for a 1989 Tracker Pro deep V 16 ft
Boats are not like cars. What info are you looking for
71cudaman
I need to know how to get to the tubing that runs from the transom to the airator in my live well. It leaks and I need to run new tubing.
jbcurt00
Dig in & trace, no document ever that showed that. Not even at Tracker in 1989
here is a misconception about recreational boats: things are documented
here is the truth about recreational boats. not even tracker has a wiring harness drawing, routing for plumbing or even an idea of what manufacturers supplied common hardware by what serial number / HIN
your boat livewell plumbing was most likely sketched out on the floor with chaulk during the initial prototype build, and then maybe they took a polaroid of that sketch for the line workers.
all the plumbing in your boat is poly tubing and plastic fittings. plastic lasts at most 5 years. you have to pull your boat apart and re-plumb it.
71cudaman
That is what I figured would need to be done. The boat is old but in really nice condition. I will have a nice winter project.
