Can somone tell me if this still good?
hvluve
Came out from a 70 hp force.
Bifflefan
Re: Can somone tell me if this still good?
Looks like its probably ok still.
Is there any cracks in it when straighten out the fins?
But its out, why not replace it now instead of haveing to take it apart again later.
Nordin
Maybe it will work, but????? Why not replace it, it?s cheap and sooner or later it will stop pumping, then you may overheat the powerhead. That costs alot of dollars.
SeaKaye12
If you compare it to a new one...you will immediately see the difference. On a new one...the vanes are straight.
Will yours still work? Sure.
But; you already have it apart.....go ahead and replace it. It would be silly not to.
Chuck
hvluve
Thanks Guys, I will go ahead and replace it with a new one.
Bifflefan
Chuck
Just FYI, if you install a new one for a few weeks and dont run it at all, then remove it, the fins will be curled.
hvluve
I got a new one today and the fins was straight but after I install it turn curled is this normal?
Vanover
here you go. As mentioned above.
jason32038
Yes it is normal. Good choice on replacing it...that one might have lasted one more season but it's not worth the risk.
Frank Acampora
It is good practice and preventive maintenance to replace it, however, that impeller is still good. Notice how there is no wear at all at the vane tips and the center mold lines are still showing on all the vanes. It may not have been used at all or has very little running hours on it. The vanes are bent because they have taken a "set" from sitting inside the pump. This is normal. Save it for a spare.
