Can you help me ID this heat exchanger?
Fouled Plug
Ensign
I have a heat exchanger from a fresh water cooling system that I'd like to know the application to. It is made by San Juan Engineering. It is 4" in diameter, 27" tall, and has removable rubber caps on each end. It has oil cooler fittings on the base. I tried looking for a San Juan website, but had no luck. If anyone knows where this cooler would work, it will greatly help me out. It's hard to sell when I can't say what engine size it will cool! :confused: Thanks!
Fouled Plug
Ensign
Re: Can you help me ID this heat exchanger?
Thanks, Bear. Mine looks a bit like this:<br />
<br /><br />Hope this pic comes out. I believe it is a vertically mounted unit, though I may be mistaken. :confused:
theboyner
Hi I didn't get the Pic but from the description i believe you are describing a 4" exchanger which would fit Merc cruiser 3.7 L engine. I have one in the back of my truck as i froze it up this winter and am looking for a replacement. We Should Talk. Theboyner
Hmmmmmm
April 16th, 2002, 10:02 AM​
See that date????? :eek:
Answering posts from deep in the archives is not really good practice.
Please pay attention to what you have brought up from the depths and use them as reference.
