Cannot use trim assist 2022 yamaha
TBarCYa
I have a 2022 300hp with the 6x9 binnacle and 6ym display and when I try to turn trim assist on I get the message "you cannot use this mode". Right now it's on the trailer and not running but I've never been able to get past this message even when running.
I performed the zero calibration and set the presets for idle and 3500rpm just to see if anything changes. Is there something special that's needed for this to work?
Thanks
TBarCYa
Have a look at this vid and see if it helps
I watched that and unfortunately I can't do the very first step. As soon as I turn trim assist on I get the message "you cannot use this mode".
Sorry, I have nothing, not even able to find how to install
lakensea
Here's a novel idea - since it's a new engine, why not ask your installing dealer why it does not work?
TBarCYa
Because I don't want to be without the boat for 3 weeks while it sits on their lot waiting for someone to look at it.
Prophammer
If you could check all the connections without voiding your warranty - something could be not plugged in all the way - just a shot in the dark
TBarCYa
I found the answer. I called the dealer and after talking to two different techs I was told that there are 5 presets for trim assist and apparently all 5 need to be set in order to be able to enable trim assist. The video posted above does show setting all 5 but never says that all 5 are required.
