Cant lower manual tilt motor
meddo
I picked up another '69 Glastron, this time a V176 with a 70's 1150 inline 6. The problem is that the motor is all the way up and I cant seem to find a release latch. I will be ordering a service manual as soon as I determine the engine year. <br /><br />Thanks
tashasdaddy
Re: Cant lower manual tilt motor
i'got the opposite problem, can't find a latch, to keep it up. not to jump your thread. thought it would be interesting.
Meddo, The latch on those was on the midsection. When the motor is tilted all the way up, you should see a "dog-eared" shaped piece of steel on both sides of the midsection, which should be touching the clamp bracket. Usually they rust and bend up, and just jam the motor up.
meddo
Chris1956, I saw those "dog-eared" pieces of steel and I think you are right they are rusted on. I'm kind of disapointed that such a big heavy motor doesnt have power tilt/trim it must be a pain to move up and down.
Meddo, Power Trim/Tilt was optional on those motors. I have it on my '77 1500, and cannot imagine not having it.
