- Joined
- Apr 17, 2002
- Messages
- 71,442
Re: can't plane or maybe another issue.
Ayuh,... This is Wrong.... It's only backfiring at WOT... It's going LEAN....
If it were Any of your ideas, it'd do it ALL the time...
The prop may turn slightly in neutral from the oil viscosity...
To backfire through the carb, either your timing is off (getting spark while intake valves are open = low power), or you have a stuck valve/valves
Only other thing I've seen cause backfiring through carb is severe carbon build up on pistons.
