carb cfm?
jdcook
I am looking for a new carb for my boat, 1988 gm 4.3l v6. just upgraded the cam, manifold, intake etc (added about 40-50 hp). I need to add a 4 bbl carb, found one on ebay but it is a 750 cfm, I am thinking that this is too big, am I right. :confused:
Re: carb cfm?
Mercruiser uses the Merc./Weber/Carter/Edlebrock...........<br />CFMs are 600 or 650........<br />I Love Mine.......<br />Real Easy to tune,with the Carter Strip Kit.......
Northern Eclipse
Re: carb cfm?
I just put a Edelbrock Performer model 1409 on my Merc 350 mag, its 600cfm and has electric choke, the carb is really a weber, but Edelbrock really sets them up nice.
Re: carb cfm?
JD- Wow, that is a lot of HP to add to that V-6. Let me know how it works out for you in terms of performance and reliability. That HP Increase puts you well within the smallblock crowd!
jdcook
Re: carb cfm?
chris, <br />gimme a few weeks and i will give a report on how well everything goes.
jmeydenbauer
Re: carb cfm?
JD,<br /> <br />40-50 is a lot of HP to add, so much so that I would be skeptical of those numbers on a 4.6l especially given that you're still using a 2 bbl carb. Anyway, you generally need the engine size, max RPM and Volumetric Efficiency of the Engine (VE) to figure the optimal carb size for your motor. A typical VE is @ 85-90% for normal engines. Given a VE of 90% with your engine size, the following info should give you a good ball park figure for the size carb to use.<br /><br />A 750 CFM to @ 9000 RPM<br />A 650 CFM to @ 8000 RPM<br />A 600 CFM to @ 7000 RPM<br />A 450 CFM to @ 5500 RPM<br /><br />In my opinion, too much carb is worse than too little. In other words, don't buy that 750 CFM if you're only going to be running at 7000 RPM max.<br /><br />Hope this helps.
Re: carb cfm?
A Merc 4.3l Gains 30hp with the 4bbl......<br />Add a Manifold.....<br />A Little Port Matching.....<br />And a few More Little Tricks.......<br />A Cam can Help, If you Don't get too Crazy.......<br /><br />40 or 50hp is Not Out of the Question......
jdcook
Re: carb cfm?
added an edelbrock intake manifold, 4bbl edelbrockcarb, comp cam, and new rocker arms.<br />we ought to get at least 40 more hp.<br />can't wait to see how she does on the water.
