carb help on mercury xr6 150
dogmam
Hi i have a question about my motor I rebuilt the carbs and put in new carbon fiber reed valves from CCMS i was having idle problems now when I unplug spark plugs 2,4,6 and start the motor it runs fine and i can adjust the idle screw but when i unplug 1,3,5 and have 2,4,6 plugged up its hard to start and the motor won't stay running what could be my problem
Could be Carbs, could be Ignition, could be Compression
Is it in the Water, or is it on the Muffs? A V6 can run on the Muffs just fine, with 1/2 the Cylinders not firing.
Being that their are 2 separate Ignition Systems on that motor, and it appears that the Odd Cylinders appear to be firing, and the Even Cylinders can't keep the Motor running, I suspect one of the Switchboxes may be bad.
How long have you owned this Motor?
dogmam
I just got it in March the guy i got it from said he only had it out a few times the boat is like new it runs good at wot I did the testing on muffs not on the water
dogmam
I took the coil packs off the bad side and put them on the other side they ran fine
I just got it in March the guy i got it from said he only had it out a few times the boat is like new it runs good at wot I did the testing on muffs not on the water.
Yeah, pretty much every used Engine runs like new when it is being sold...
So you took the Coils from 2, 4, and 6, and put them on 1, 3, and 5, and the Motor ran on 1, 3, and 5?
If so, that shows the Problem on 2, 4, and 6 is Upstream of the Coils.
Have you checked for Spark using an Adjustable Spark Tester? All Cylinders should have a Spark strong enough to jump a 3/8" Gap
If some don't have spark, you could have a Damaged/Shorted Wire going to the Switchbox, or the Switchbox is bad.
Here is a Link to a Ignition System Service Guide
dogmam
i will get one and check it do you think it could be my ignition controller that might be going bad
Dukedog
what year XR6?.. makes a difference with type of 'lectrics.... pre 2000 it has a switch box ignition.. after it will be a cdm type ignition...
send me an email addy and i'll send ya an oem manual for it....
dogmam
It's a 2002 whats your email
dogmam
So mine don't have a switch box it's a controll mod I unplugged it no change so now im looking at the trigger and I see it has been replaced in 2021 so I will see what it checks out
dogmam
You should do PMs when discussing e-mail Addresses
jimmbo, thanks for all your help i think i got it fixed there was 2 ground wires going to the control module I tighten them up and it seems to be running a lot better
Poor/corroded Connections have caused many an Engine to run poorly
