Carb kit and fuel pump kit
paddymichaud
Thanks to roscoe I now know that my motor is an 1983 Force 85 HP.
My model is 856XC3L
Now, I want to change the impellar, get a carb kit, and a fuel pump kit.
Question is which one? I am a little confused.
For the carb kit I see 4 different options
Sierra
18-7033
18-7037
18-7216
Mallory
9-37000
Fuel pump seems pretty straight forward
Sierra
18-7806
Impellar kit
I'm trying to cross reference with table on mercruiserparts but can't seem to match any of the parts from iboats.
Any help is greatly appreciated.
Patrick
azlakes
Re: Carb kit and fuel pump kit
My model is 856XC3L
Impellar kit
Patrick
...hiya paddy
give these folks a jingle or check the website. got a referral to them from a member cause iboats did not carry the imp kit. i went ahead an ordered the housing but check yours and if ok it may save you some money.
Originally Posted by azlakes
Rob, go to www.maxrules.com. ...about 9 bucks shipping and 70 for the impeller and new houseing, it comes complete with new bolts , plates and all.
paddy - the part numbers on mercuiserparts, are the Mercury factory part numbers.
The part numbers you find elsewhere , are aftermarket parts producers.
So they are not going to match up.
For the carb kit, you will need to id which carbs you have.
The WB-21 carbs, use the 18-7033 kit.
The WE-4 carbs, use the FK10177 factory kit.
You need the 3065 impeller.
Or the 2011 water pump kit.
Maxrules is a great source for Force parts.
paddymichaud
I checked my carbs today and they are WE-4, so I'm gonna go ahead and order the FK10177 kits from maxrules.
I'm also gonna get the 3065 impellar and the 18-7806 fuel pump kit.
Thanks for all the help. I will keep you posted on my advancements.
