carb kit for two barrel holley ??? maclin or don please
Senior B
Re: carb kit for two barrel holley ??? maclin or don please
Is yours the Holley model 2300 500 cfm?
brian wig
2312 is last numbers on the horn
brian wig
The diaphram on the power valve was bad thanks guys nice to have so many knowledgeable people to turn to!
Senior B
What model Holley 2brl? Mine is a Holley 2300 500 CFM and the proper kit was 703-36. It had everything except for a float, but my old one was fine. Had the correct powervalve too. I got it for $22.00 from my local Advance Auto Parts store. Once you get the model number, you can go on the Holley web site and look up your kit. They can be gotten from e-bay, but I found those prices quite high. Any auto parts store should be able to get it for you in a couple days.
brian wig
thats where i called and they had the parts again thanks for all your help
brian wig
the number on choke horn is r82028-1 2312 what series carb do i have so i can find a gasket or will silicone work?
Maclin
It is a 2300 series, although many variations.
If you mean the whole carb kit then you can search with the r82028-1 number online at Summit or Jegs or Holley and find the kit#.
If you mean the base gasket then Holley or Jegs or Summit Racing should have that also, should be able to look that up by category starting with gaskets, then carb base gaskets, then 2bbl, then Holley brand, etc.
Could also look at a parts house, they usually have stuff like that on a wall somewhere.
Do you have the original one to compare to? Also note the intake manifold configuration, whether or not it is 2 holes, one for each barrel or an open oval.
Do not use silicone. Base gasket to manifold and Carb to base gasket should be dry.
