When the engine is raised in trailer mode,, gas runs out of the carbs . Is this normal ? Surely not
B Baja Boater Cadet Joined May 21, 2015 Messages 20 May 22, 2015 #1 When the engine is raised in trailer mode,, gas runs out of the carbs . Is this normal ? Surely not
B Baja Boater Cadet Joined May 21, 2015 Messages 20 May 22, 2015 #3 Sorry , Inline six two stroke 1988 serial OB207133
C Chris1956 Supreme Mariner Joined Mar 25, 2004 Messages 28,797 May 22, 2015 #5 Yes, it is normal. You will likely see a little plastic pan under the bottom carb to catch and route the spilled fuel.
