Carburetor ?/ Added Fuel Pump ?
daviscfad
When i go to bolt my carb. to the manifold.. How will i know if i need an adapter plate between the two... Or can i just use a gasket.. Its a edelbrock carb and manifold.. I will take a picture in the morning if necessary.. I am sure i am not giving you enough info so just let me know what else you need:D
Re: Carburetor ?
Re: Carburetor ?
Ayuh,... What motor you're workin' on would be Nice....
If you're using the Edlebrock Carb,+ Manifold package,...
I Doubt you need any sort of Adapter plate...
Fishermark
Re: Carburetor ?
Re: Carburetor ?
If you have a spreadbore manifold (Like the Edlebrock Performer) and are putting on a square bore carb (like, ironically enough, the Edlebrock Performer) you MIGHT need an adapter. There is usually enough "meat" to make a good seal, but sometimes not. Basically, bolt it on and take a look and see if it seals well enough.
daviscfad
Re: Carburetor ?
Re: Carburetor ?
Its a 454 not sure the year
I am not sure what spreadbore is or if the carb is square bore!? I have to buy a bolt kit before i can bolt it on.. Let me know if you need a picture
Fishermark
Re: Carburetor ?
Re: Carburetor ?
Here's a spreadbore:
Here's a squareboare:
Here's an adapter that you may or may not need:
daviscfad
Re: Carburetor ?
Re: Carburetor ?
here is my manifold and carb picture... Will i need a stud comming from the manifold to the center of the bottom of the carb or will she just sit on the 4 mounting studs??? And i guess i will ask will i need that attachment or just a gasket
Fishermark
Re: Carburetor ?
Re: Carburetor ?
You have a square bore manifold and carb - in fact it looks like a Performer RPM Air Gap manifold.
You only need the four mounting studs at the corners. The center stud will go from the carb to the flame arrester and has nothing to do with the manifold.
All you need is the gasket.
daviscfad
Re: Carburetor ?
Re: Carburetor ?
Ok Now that i have my carbuerator Covered I have a fuel pump ? I have a 454 Serial number 10114182.. I think it is a Gen V.. It does not have a spot for a mechanical fuel pump so i am assuming i have to go electric? I have checked the block over and did not see a block off plate or anything that wouldresemble where a mechanical fuel pump would go... Can someone help me find the right electric fuel pump.. I am sure just any ole one want work
