carburetor Jets
james williams
I worked on a J150glsrm that burned pistons on port side.My question,what is the purpose of smaller jets on the port bank[high speed jets] Thanks. james
Faztbullet
Re: carburetor Jets
The all should have been 69's on high speeds jets. I wonder if someone read the parts breakdown wrong and replaced them?:confused:
tashasdaddy
Re: carburetor Jets
sounds like some screw up rebuilding the carbs, i now have a magnifing glass to check the # when i rebuild one. got them mixed up. boy, it ran horrible. then found the problem.
