Carrier Assembly Oil Seal
gabe1
Hello
Last March I Pressure tested my Alpha One at 15psi for 24 hours
No loss of pressure what so ever.
I pulled the drive for the winter and I found about 1/8 cup of gear lube(No Water)
So I pressure test the drive again 15psi for 24 hours no loss again.
If the Carrier Assembly Oil Seal is bad why am I not losing any pressure?
Thanks
Gabe
Bt Doctur
Re: Carrier Assembly Oil Seal
If it is in fact gear lube ,it`s a "rotational leak". replace the seal and inspect the input yoke for any grooves.
