Carver Santa Cruz Restoration
Status
Not open for further replies.
bluewavecaptain
Well...I've put it off long enough. It's time to give my old girl some new life. I've posted a few pics of my boat here. The link to the full album is below. So here's the story. This boat belonged to my grandfather, so please don't tell me to scrap her or sell her. She's family. :) Anyways, she hasn't been in the water for over 10 years. Unfortunately, for a long time, my finances didn't allow me to invest any serious money. When I got the boat, I started the motor and it ran great. That was 7 years ago. Since then she has sat (let the tongue lashings begin). Unfortunately, last year a raccoon got inside and did some damage and managed to crap all over the boat (seen in the pics). I pulled the outdrive a few years ago to restore it. There was no water in the oil, but oil had leaked into the the gear bellow. The prop had a crack in it on one of the blades. I have the outdrive in my garage awaiting a rebuild.
So here's the plan. FIRST, it will get a thorough CLEANING! I will be using bleach too. Stupid raccoons... The hull is solid. I went over the hull with a large wrench (thank you, Friscoboater) and everything is solid. No hollow spots. The stringers are solid and there's no signs of delamination. The bulkheads are solid....but they are bare wood, along with the engine mounts. They are covered in gelcoat though. I will address those at some point. The cabin is another story. All the wood framing underneath the fiberglass cabin shell is rotting or rotten. The plan is to remove the components of the flybridge, lift the cabin roof, and rebuild all the structure for the cabin. Of course, thanks to Friscoboater's videos, I'll be using resin soaked marine grade plywood, fiberglass, and PB to rebuild the cabin structure. The other plan this year is to pull the engine and go through it. I'm thinking the gaskets in the exhaust risers are bad. There was never water in the oil when the engine ran. However, if you let the engine sit for a couple days there would be a "layer" of water in the oil. My thought is that water is seeping back in through the exhaust valves when the engine isn't running. When the engine is ran, the water disappears. No grey oil. The oil is black as night. Any other thoughts? Oh, and I have to drain the gas tank. I don't think she'll run on 10 year old gas. The dang thing is full too...
Sorry for the rant. Just thought I'd bring everyone up to speed on my restoration plans.
jbcurt00
Copy the IMG code for a pix youwant to.post and paste it into your replies
W numerous pix of standing or frozen water, how did you check the stringers to confirm they're solid?
bluewavecaptain
The water is only in the engine bilge and only in the center section. I tapped on the stringers with a mallet. I didn't want to go drilling holes yet without something to fill them with. Nothing sounds hollow. Everyone sounds solid.
bluewavecaptain
Man, I certainly hope not! I'm already dreading pulling the cabin roof. Judging by the complexity of the deck and cabin structure, getting to the stringers would be a challenge...
Only way to be sure, wait til spring and either use a moisture meter or test drill
No Title
I have this boat...been working on the same thing for many years, slowly but surely. I have to say mine was never in such bad need of a pressure wash...but you've got a great boat under there and I'll be glad to help any way I can. Selfishly, I'll also say that if you do have a change of heart, I want to help you part it out......but let's hope you can do the restoration.
bluewavecaptain
Haha! Sorry, Captain, I'll never part with her. She was my grandfather's boat and he and I were very close. Lost my best friend. The biggest issue is that the boat is stored by my parent's house, which is surrounded on 3 sides by trees and swamp. So, constant baths are a must. Since the raccoons have been in it, I'm going to give it a good scrub down with bleach and then a good carwash soap and then a hand wax. It's definately my fault that she has been neglected the last several years. I appreciate your help and I'll and you to my "friends" list in case I have questions.
carver 2866
I am redoing my 1979 carver 2866 right now all new inside and new look on the out side adding countertops more seating and much more room in the floor area. led lights can't wait till she's done.. I would have an old carver anyday over a new one !!
Status
