champion or ngk spark plugs
goodtimesfishing
What is the preferred spark plug for a 88 50 hp force, champion or ngk? Also is ngk-BUHX and champion UL18V the plugs with or without the conventional bent ground electode? Which one would be best?
XiViperI
Re: champion or ngk spark plugs
Ngk for two stroke. Champion for 4 sroke/ inboards. I think. Every 2 stroke I ever had ran Ngk. But they were all yamahas. ;)
ngk buhx
http://sparkplugs.com/results_cross.asp?pid=buhx&x=35&y=13
image.asp
buhx or Champion L20V
fucawi
Banned
If your motor is running OK with the surface discharge plug then stick with it as the wrong side electrode plug may give rise to pre ignition and hole your pistons.
goodtimesfishing
Thanks for the info. PO put side electrode type in it, but I will be putting the proper ones back in it today! Don't want to risk any hole in my pistons.
